DrNip's Weld-Craft 1248 - Hit 32.1 MPH!!!
DrNip
Post by DrNip »
I can either attempt to paint it myself which will probably be trial and error as well as suck or buy a wrap. The wrap to me looks the best and easiest.
RStewart
Post by RStewart »
That is one sweet ride. Can't wait to see it when your done.
14ft Richline semi v
Sinner by birth...Saved by the Grace of GOD!!!
huntinfool
Post by huntinfool »
Nice place to start, you have some good plans to.
DrNip
Post by DrNip »
I'm starting to gather parts for the livewell. Didn't realize how much it was going to cost to assemble. I want it done right instead of the way it was setup which is janky. Electrical and flooring will be next followed by the purchase of the outboard sometime in the 1st quarter of 2014. Still debating the camo. I believe I have devised a method to hand paint the camo which in the end would probably look the best. I'll have some pics soon.
RStewart
Post by RStewart »
Yep, to do the live well right can get pricey. But in the end it will be worth it I think.
RStewart
Post by RStewart »
Did you ever get your live well done?
DrNip
Post by DrNip »
No because it's been too cold on my days off. Haven't purchased garage door insulation panels or gas heater for garage either. I swore last winter I would by this winter. Now I'm swearing by next winter I'll have them!!! Lol
Also been busy with the holidays, bowl games and family getting sick.
RStewart
Post by RStewart »
LOL. I hear ya. Same reason my boat hasn't been touched in awhile. I need to get on the ball & get my cooler/live well finished & do a little repair work on my rear deck.
DrNip
Post by DrNip »
I hope it warms up soon so I can get on the grind because spring is going to be here sooner than later and I don't want to rush it together.
DrNip
Post by DrNip »
Well the day is finally upon me to purchase my motor. I will be going down on my day off this Monday to the boat shop to purchase it. I have narrowed it down to the following two brands:
25 HP Tohatsu or 25 HP Evinrude
Plenty of places around here work on them. I am almost certain I will get the Evinrude. What I am contemplating is if I need electric start as well as power tilt and trim. I am leaning towards yes on this as well. Thoughts?
typed by ben
Post by typed by ben »
DrNip » 30 minutes ago wrote:Well the day is finally upon me to purchase my motor. I will be going down on my day off this Monday to the boat shop to purchase it. I have narrowed it down to the following two brands:
i have an electric start evinrude- first motor i ever bought that wasnt part of a boat package. i looked at it like this:
electric start positives:
1. if i get disabled in an accident on the water to where i cant use my arms or legs, i will want a push button start to try to get to safety
2. electric start is a little more luxurious
electric start negatives:
1. battery weight
2. no rope start to fall back on if the battery dies or the starter motor takes a dump
if i could go back i probably would have waited for a pull start version of the same engine to pop up on account of those two negatives. the electric start option on my motor means i have to have yet another battery in the rear in addition to the two that are already up front.
Lowe 1648M | 25 hp Johnson electric start | Minnkota 40AT
always in progress.
DrNip
Post by DrNip »
I believe the electric starts have rope pulls too. I figured I would hook the motor up on the same battery as the electronics, pumps and lights battery. Then have the trolling motor on a separate battery.
RStewart
Post by RStewart »
They usually come with a rope to use of its needed. I've seen them where the route isn't on the motor. If you need to use it, you pull the cowling & wrap it around the flywheel & pull.
typed by ben
RStewart » Yesterday, 22:20 wrote:They usually come with a rope to use of its needed. I've seen them where the route isn't on the motor. If you need to use it, you pull the cowling & wrap it around the flywheel & pull.
my 150 rude had that but not my 25. doesnt even have a provision for it on the flywheel. there again it was an old state surplus motor so they might have ordered 25 custom motors for their specific need.
always in progress.
DrNip
Post by DrNip »
Alright, alright, alright, time to get this thing finally going. I'm a month behind schedule due to work, family and too cold of weather. I had plans of ordering my motor on 2/1/2014 but that has come and gone. I'll be going down and ordering it 3/1/2014.
1st order of business was building a casting deck. Ain't no wood here! Big thanks to New River Rat as he helped solve my problem of how to construct it by his design. Mine was 25" long so I had to add an additional set of support legs in the middle as well as some angled aluminum along the sides.
Here is the mock up of it with cardboard. Glad I did this as my original measurements were off about an inch. I really wanted the front side of the deck to be bent under like the back but that was a challenge seeing where it would have connected would have varied 95 - 105 degrees. So I opted to just run the deck over the existing piece of factory aluminum.
Here was the design I sent to discountsteel.com. The piece came out perfect. I went with the 1/8" sheet.
Got the piece back and a perfect fit! :)
Here it is welded all up. Lovin it!
Also had the welder weld up around the livewell drain hole where it was leaking.
I've contact Weld-Craft about getting some paint mailed out to me so I can get the deck painted. I thought about just trying to find something locally to match but decided against that as in the end it probably wouldn't match and I would be dissapointed.
Purchased my trolling motor battery box, livewell handles, seat and a few other odds and ends.
Yeah I went with a cheap seat but I only weigh 155 and found this style of seat more comfy than the big cushioning ones. It also soothed my wanting to paint my boat camo itch I had. Found this at Academy for $19.99.
I decided to hold off on installing all my livewell parts until I get the boat on the water with the livewll full and motor on so I can get my overflow holes just where I want them. Right now it would just be a guessing game. Once pumps and hoses are ran I can start putting in the flooring. Won't require much aluminum but it will need to be done.
Stick around, more to come! :)
