58 Richline, resto mod
OutrageGIS
Post by OutrageGIS »
Made a landing block for the bimini frame from shaped poly board and rubber light pole mount from Walmart. The poly boards line it up and the pole mounts hold it down .
1958 Richline Big 16 Center Console resto mod:https://www.tinboats.net/forum/viewtopi ... 21&t=33752
OutrageGIS
Some more pics of interior
OutrageGIS
And then there is the motor... Boat came with an unproven 1968 Mercury 350 35 HP electric start. PO stated that it "Ran great, used to start it every week then one day wouldn't start. Mechanic said something about the electrical system..."
So, ended up redoing all wiring, internal and external harnesses as well as rebuilding the check valve (fuel pump), carb, all tank plumbing and fabbing all new internal fuel lines. Then to lube cables and re set adjustments, disassemble and lube control box. The manual was indispensable for this. Seems to run pretty good after getting the idle dialed in.
Nobody made a repop of the decal set but I found a Company on ebay who made a set for the 1968 20hp. After contacting them they said they could do a set for the 35. The company, DecalFX, is located in canada but I got my decals within a week. Highly Recommended https://www.ebay.com/itm/161447694760?_ ... EBIDX%3AIT
The original "Phantom Black" is glossy and I prefer the look of a matte finish, so I used a matte black for automotive trim. I used it on a car resto 4 years ago and is still holding up great even in the weather. We will see how well it holds up to the environment. I am happy with the results.
OutrageGIS
Got her wet for the first time today. Did great, motor pushes her nicely. Trolling motor controls well. Need to practice loading and unloading a bit more but overall great first run
Y_J
Post by Y_J »
Woot.... Congrats on the getting wet.. As long as you had fun, that's what counts. :)
My Fisher-Marine 1648 Build Thread https://www.forum.tinboats.net/viewtopi ... 96#p434296
My Sears 1236 Build Thread: https://www.tinboats.net/forum/viewtopi ... 21&t=34781
Happy Boating & Fishing,
YJ
1979 Fisher-Marine 1648
Minn Kota 35 lb thrust Bow Mount TM
Mercury 20 HP OB
1974 Ted Williams 4.5 HP OB
OutrageGIS
Thanks, Y J, I was starting to think I wouldn't get it finished before freeze time! Now for some fall fishing!
OutrageGIS
Took her out for another river spin today after adjusting the throttle cable for more top end. Also raised the angle of the outboard 1 pinhole. Noticed some slop in the magneto advance actuator on the throttle linkage, upon disassembly the actuator is missing two plastic bushings. The slop from the missing bushings is preventing the spark advance from returning to zero at idle. This explains the rough idle I noticed while loading today, though it ran great at high rpm for an hour and a half straight. The bushings are no longer available, but I found a used set on ebay. Needs more pull still to get full throttle, I will wait until I have replaced the bushings before I adjust it any more. Today I GPS'd 15 mph upstream and 18 downstream. I should cruise comfortably at 20 mph when adjusted correctly.
Kismet
Post by Kismet »
Outrageis? I REALLY like the boat you made!
=D> =D> =D> =D> =D> =D>
Kis
Enjoy every sandwich
1955 Alumacraft Model A
https://www.tinboats.net/forum/viewtopi ... 08&start=0
1959 Alumacraft Model F
https://www.tinboats.net/forum/viewtopi ... =3&t=25386
1980 Alumacraft Model F7, 1955-56? Johnson 10hp
viewtopic.php?f=4&t=35326
1956 Alumacraft Model RB
https://www.tinboats.net/forum/viewtopi ... =3&t=39249
OutrageGIS
Thanks Kismit! Turned out pretty good just didn't plan on it taking all summer. When I got the boat I thought I would just fix the motor and be fishing in June! I blame this great site for giving me an overload of inspiration and ideas.
Got the throttle linkage parts in today, probably won't be warm enough for another water test until next week, but they look pretty good for 46 year old plastic bushings. Otherwise the motor seems real straight.
OutrageGIS
Had time to run back down to the river after replacing bushings. Better, smoother response to throttle, but still needs a little more pull on the cable, hopefully the last adjustment
OutrageGIS
Took my 7 year old out for our first trip. Didn't catch any fish but had a great time! Boat did great.
Y_J
Post by Y_J »
Looks like a couple happy campers there. Right on.
YJ
Mercury 20 HP OB
WPS
Post by WPS »
Boat looks great & you done a great job!
Nice work!
John 3:16
2013 Sun Tracker Bass Buggy 18' DLX Pontoon
1978 S-14' Lund Aluminum V-Bottom With Aluminum Trailer...viewtopic.php?f=21&t=36187
1978 Elgin 12' Aluminum V-Bottom
