Johnson 3 cyl 35 hp - Runs for while then dies
rktman
I inquired in another post about a possible fuel pump issue but I'm starting to think my 3 cyl Johnson 35 hp is having electrical issues.
I took it out last weekend and it ran fine for a 20-30 minute run.
I stopped for a while to fish and then tried to take off.
It sputtered and died like it was fuel issue.
I pumped the fuel bulb and it started and ran for 30 sec and died again.
It repeated this for 5-6 times.
I took the case off and checked for fuel in the filter, loose connections, etc.
I started it and it ran long enough to get me to camp.
The next morning it started and ran fine for 20 minutes back to the boat dock.
So, this weekend I did the same thing.
Ran for 15 minutes up river, stopped to fish, ran 10 minutes down and it sputtered and died as before.
Then it was the repeated Start, run for 30 sec, die.
Sorry for the long post but does this sound like a powerpack issue?
Honestly, I've been afraid to shock myself to check but I will get an inline spark tester and check it this weekend.
all you have to do is when it happens take a plug out of the motor and ground it to a bare metal engine part and crank it and see if there is spark or not
you could make a simple jumper wire with alligator clips on each end and ground it that way so you are not holding it
but a spark tester is fine too
Make sure that the breather on fuel tank is working run it till it shuts off open the cap and pump the bulb leave the cap loose and see if it runs
Sent from my XT1254 using Tapatalk
I had a similar issue with my 9.9 merc. I had a 6 gallon fuel tank with a vent in the cap. I just dealt with it for a while. Then for a completely different reason I switched the tank. I wanted a smaller tank to save room and weight. I got an Attwoods 3 gallon ventless tank. I have not had an issue since.
"Sputtered and died" is not a good enough description to go on.
What RPM were you normally running at when this happened? On plane? Idle?
Did the engine shut down as if you turned off the key so to speak?
Hint here is that a fuel issue will be less abrupt than ignition issues.
If you try and start the engine immediately after one of these shut downs what happens?
If it will not do anything no matter what you try then later starts if nothing ever happened that would be good information as well.
Fill in the gaps here and we can start on it.
I would not remove a plug and hold it against the block by the way. Plug wires are short enough that the spark may catch the fuel blowing out of the cylinder and light it off. Inline spark checker is the easiest followed by mechanical spark checker.
Thanks for replying Pappy,
Full RPMs and on plane when it cuts out (after the first 15-20 min of running)
It does not quite shut off all the way. It will idle a few seconds and then finally die out like its being starved for fuel (primer bulb pumping does not help, vent is open, fuel system seems unrestricted). Water is coming out the pee hole at the normal rate.
After a little while (30sec -1 min), it does start back up and will even get to full RPMs and back on plane for 10-15 secs (thankfully it will get me over a thin shoal before it cuts out again). The longer it sets the longer I can run (especially with case off).
I went by the parts store and purchased an inline tester, will try it out as soon as possible.
A buddy mentioned that it might be the thermal sensor throwing it into slow mode, not sure how to check that without replacing.
It is a jet and not real easy to try the hairdryer trick.
Seen this too many times to remember loosen the cap on the tank bet it will run all day I have even seen fuel tanks cause this with the carbs full of gas and the more gas that is in the tank the less time it will run before it shuts off
I agree with hildebrandr990. That was the same thing that happened to mine. I think it was getting vapor locked. When I switched the tanks out it stopped.
There is a simple check to verify what is mentioned above is happening.
The primer bulb will be sucked flat while the issue is occuring. If the tank cannot supply fuel for whatever reason the resultant fuel pump vaccum will flatten the bulb.
Easy check.....take another tank with you.
There are two fuel pumps on that engine but you can always squeeze the bulb (as long as it is not flat) to verify a fuel supply issue to the engine.
No suck flat going on, but I do have a spare tank and newer bulb. I will take it with me on the next outing.
Ok, it is not a fuel issue
It is a hot fail spark issue.
I tried the tank swap, took lid off tanks etc, primer bulb is good and has pressure.
It will run fine with the motor cover off.
If I run it for 15 min and let it set with cover on, the heat accumulates and causes a failure somewhere, I assume the power pack is the most common failure point?
Hey bud have been having same kind of issues with my 3cyl 25 Johnson, you can usually tell if the switch box is acting up on these motors because either the quickstart doesn't activate on startup or never shuts off leaving it on high idle, unfortunately there is no way to test these packs, and new OEM one will set you back almost 500, optical timer base isn't cheap either. I've changed carb parts, rebuilt fuel pumps, even changed all fuel lines through out, and reset idle needles on mine, helped a little, but still wanting to die after restart and running down the lake. If you have service manual, go through it, and look at the idle sync section make sure all that stuff is set correctly, mine wasn't and mine was installed by an OMC/BRP dealer who should've known better, that was bought to my attention by some other members on here, that I needed to check that stuff before proceeding, it helped a bit, but I too am in suspect of the switchbox now. On these motors they are notorious for going bad, the newer version of box after 1999 is supposed to be better, but have heard of guys burning newer ones up too.
Jaguar Jim,
What did you mean by the quick start?
I've noticed it takes a few times trying to start it (2-3) before it fires up (even after running for a while).
Before it would start right up.
Thanks.
rktman said:
Jaguar Jim,
Thanks.
I found this for you doing a search from a post on Iboats
QuikStart is a feature of the powerpack that advances the timing whenever the engine is started. After five seconds, the timing will return to normal if the engine temperature exceeds 96 degrees or if the RPM exceeds 1100, whichever occurs first. The change in timing is quite noticable.
Most of the QuikStart powerpacks have a black and white wire from the temperature switch on the cylinder head in addition to the normal tan wire for the alarm.
I know this is old but I still haven't tracked the problem down yet. Purely by coincidence, I watched a guy running his Evinrude 3 cyl 25 hp (same motor as my Johnson 3 cyl).
His did the exact same thing. It will run fine for a 5-10 minutes, then starts coughing, then just dies. Wait a few minutes, runs fine (only for a brief period), shuts down..repeat.
Pumping with a hard bulb doesn't change anything, fuel is in carbs and filter. Like me, the other guy replaced plugs, CDI box at $400, switch primer bulbs/tanks, cleaned carbs, checked compression, stator checked, unplugged temp sensor, etc.
It seems to be a hot fail condition somewhere but its hard to diagnose.
Any recommendations? Its just too good of a motor to give up on.
Maybe this sounds obvious but how old is the fuel? The fuel we get now from gas pumps contains ethanol, which if left in a tank for 3 weeks or more it will start to turn to water.
I know it sounds strange but has happened to me numerous times. I only use non-ethanol fuel now, it's harder to find and more expensive but it runs much better in a boat.
Different tank, all new gas and oil mix, same result.
