- Joined
- Oct 1, 2011
- Messages
- 445
- Reaction score
- 219
- LOCATION
- SoCal
Decided that the scratches all over my hull sides and bottom were just bothering me too much! Most details bother me when it comes to my boats and I like things to be ship shape, both mechanically and aesthetically.
Sanded hull, sides, and transom with 220 grit. Removing factory decals proved to be troublesome and time consuming. Adhesive left behind after decals were removed was as stubborn to remove as I have ever seen.
Found a product called Rapid Remover. Spray it on wait about 15-20 seconds and it removes like butter! I used plastic razor blade it was fantastic and scrapping off adhesive. Highly recommend them both for removing stubborn adhesive.
I will be using one part Pettit Polyurethane paint. Thinner and performance enhancer were both recommended by Pettit. See below pics of sanded boat and paint being used.
NOTE: Repair seen in port bow has been primered with an oil-based spray primer. I also removed rub rail insert so I can paint lower half of alum extrusion.
Now I will mask 1-2 days before painting and will be rolling with a Purdy 1/4" nap roller (recommended by Pettit). If paint allows, and I can follow tipping with a brush, I will. This is a one person job so tipping may not be possible, especially since temps are near 100F by mid day.
I know rolling will not leave a spayed-like finish, but it will sure be better than all of the scratches that were on boat previously!
