SMDave
What's the difference of reel oil and reel grease? Where do you use each? Worm gear? Bearings? Thanks.
nicdicarlo said:Does anyone have any links for instructions for simple reel maintenance?
nicdicarlo said:Thanks for the info. I might make a couple mods to some bigger Abus I have this winter (drag washers and bearings) so the more info I get, the better off I'll be.
You are Santa :shock:Jim said:nicdicarlo said:Thanks for the info. I might make a couple mods to some bigger Abus I have this winter (drag washers and bearings) so the more info I get, the better off I'll be.
I plan on doing the same with a curado 100d if santa brings it lol!
SMDave said:You are Santa :shock:Jim said:nicdicarlo said:Thanks for the info. I might make a couple mods to some bigger Abus I have this winter (drag washers and bearings) so the more info I get, the better off I'll be.
Nickk said:you're not changing drag right? The D Curados have the Dartainium drag washers and should be as good as Carbos or Smoothies(I think).
Nickk said::lol:
I run ceramics in my skateboard wheels, they're fast and smooth!
Jim at Heartland said that the Dartanium washers were just as good.
You don't have to pull a spool washer on the Curado D right? It's only the old ones that had it attached?(or do you.....hmmmmm)
Nickk said::lol:
