U user 29 Well-known member Joined Mar 8, 2007 Messages 343 Reaction score 0 Jul 28, 2020 #1 Is it alright if I unplug my wiring harness to adjust the way the wires are woven around the steering cable? Thanks
M Mike_the_millwright New member Joined Jun 26, 2020 Messages 2 Reaction score 0 Jul 28, 2020 #2 As long as the battery is off, and you mark everything so it gets reconnected properly, you should be fine
U user 29 Well-known member Joined Mar 8, 2007 Messages 343 Reaction score 0 Jul 28, 2020 #3 Mike_the_millwright said: As long as the battery is off, and you mark everything so it gets reconnected properly, you should be fine Click to expand... Thanks for the battery note. I just want to unplug it, work it through so the path is direct and plug it back.
