remote trim switch
fatcat
Can anyone tell me how i would install a remote bow switch , can it be wired in from the 3 wires located in the throttle handle or would you have to hook into the harness coming into the control,s . This is for a 60 hp Merc w/ merc control;s .
Yes, you can do it either way; I installed a switch on the bow and the outboard by splicing into the switch at the throttle. It's probably easier to splice at the harness plug.
Are you looking to have a trim switch at the motor, a trim switch at the controls and a trim switch at the bow? The wiring should be there for the controls and at the motor.
