Just ordered a new rectifier for my 70hp Johnson two stroke as I suspect it may be going bad. Cheap and easy enough to replace but the new one came with an extra black wire, which I'm assuming should be grounded to the engine? Is there an easy ground location where all the wiring connects? Or should I extend the wire and run it somewhere accessible.
Sent from my SM-G975U using Tapatalk
