River boat
- 7
River Jet Jon
Are you going to take the bench seat out? It looks like it is in exactly the wrong place for your feet.
- 1
Re: River Jet Jon
Yes Sir I am but wanted to retain the boat shape so I’m gonna complete the tail first. Then cut it out and deck the nose too.....I hopeCedarRiverScooter wrote:Are you going to take the bench seat out? It looks like it is in exactly the wrong place for your feet.
- 1
Re: River Jet Jon
Roughing it in.
- 1
- 7
River Jet Jon
Having the full aluminium skin should give extra protection against failure.
If I was to start a new jet jon, I would follow your design.
- 1
Re: River Jet Jon
Oh no , now I feel responsible.....CedarRiverScooter wrote:Having the full aluminium skin should give extra protection against failure.
Ahhhhh it’s ok to blame ole Bob, ain’t the first time!
Re welded the whole thing. I’ve learned some valuable lessons, buy quality wire and tips in the correct gage and the right gas! It’s hell with bifocals.
- 1
Re: River Jet Jon
Frankenstein transom
- 7
River Jet Jon
I had better success running a .045 tip with .035 wire. Less burnbacks on starts
- 1
Re: River Jet Jon
Yeah I vw learned a few things like that.CedarRiverScooter wrote:I had better success running a .045 tip with .035 wire. Less burnbacks on starts
I’ll try the tip.
- 1
Re: River Jet Jon
Ok if it will warm up today , the plan is to join the jet ski plug with the aluminum boat! I put in 10 5/16-18 “ RivNuts “ to the supports, plan to put 3M 5200 series between the skin and plug. Use epoxy resin and fiberglass cloth to seal the inside. Once all dry , flip and do the outside.
Remind me again why I needed a Jet Jon? Hahahahaha
Have a great day everyone!
- 7
River Jet Jon
The 5200 can be runny, so I duct taped the joint from underneath to keep it from running out. I had some pretty big gaps though. Yours looks pretty precise so it is probably ok as is.
- 1
Re: River Jet Jon
Blue painters tape in place , gonna grab lunch let it warm up some and get er dun today. I hope.CedarRiverScooter wrote:The 5200 can be runny, so I duct taped the joint from underneath to keep it from running out. I had some pretty big gaps though. Yours looks pretty precise so it is probably ok as is.
- 1
Re: River Jet Jon
There has been a marriage.
- 1
Re: River Jet Jon
Welded , glued , bolted and floated out
- 1
Re: River Jet Jon
My arms and back are sore, I’m still moving!
