River boat
- 1
Re: River Jet Jon
Cutting and fitting!
Setting up my weld jobs.
Setting riv nuts
Mock ups.
Setting riv nuts
Mock ups.
- 1
Re: River Jet Jon
I need some stock Polaris SLT 700cc help?
I have a fuel filter/ separator and a chunk of hose that goes to top of the oil tank?
Everything runs now but where does this stuff go?
- 7
River Jet Jon
Fuel filter goes in hose from tank.
Maybe the other hose is for the bilge siphon system? It hooks up to the tube in the pump outlet nozzle.
- Site Admin
- 15
River Jet Jon
Ok,cool!Superfly Silverfox wrote: ↑06 Apr 2021, 15:28Yes those wooden bunks you see is it.Jim wrote:Is the boat hanging off the back end of the trailer?
It might see a county road but for the most part behind a side by side getting slipped into the river.
Please use our Amazon Affiliate link. It costs you nothing and sends a few cents to the site.
Amazon Link!
Amazon Link!
- 1
Re: River Jet Jon
Ok some booger welding progress !
- 1
Re: River Jet Jon
Cheap Amazon decking not stuck just cut.
Gonna paint everything first.
- 1
Re: River Jet Jon
One more
- 1
Re: River Jet Jon
Closer
- 7
River Jet Jon
You might want to extend the tongue on the trailer. You can get sq tubing & weld it on. Reinforce the joint well.
- 1
Re: River Jet Jon
Absolutely! But it’s really easy to maneuver right now so float test first , then the down the river test.CedarRiverScooter wrote:You might want to extend the tongue on the trailer. You can get sq tubing & weld it on. Reinforce the joint well.
It’s perfect for a side by side or 4 wheeler.
I’ve done a bunch of work fast but it’s exciting and fun now..... hopefully makes a run or two.
- 1
Re: River Jet Jon
We have steering.
- 1
Re: River Jet Jon
- 1
Re: River Jet Jon
Just lack a battery hold down and some rubber plugs.
Should be water tight
- 1
River boat
It works!
Had a couple of water leaks.
Solved.
Carbs
Solved.
Carbs
- 7
River Jet Jon
Looks like a lot of fun!
