CedarRiverScooter
- Joined
- Nov 13, 2014
- Messages
- 1,522
- Reaction score
- 4
This year both of my lawn mowers (one 35 years old, the other 1 year old) had clogged carbs after storage. I always buy non- eth gas, which is quite a bit more expensive. I added sta-bil to fresh gas last fall & ran the carbs dry.
I am wondering if they sold me ethanol thru the non- eth gas. Not trying to start a conspiracy theory here.
I found this way to test, so I will be doing this next time I get gas. Note I haven't started my outboard yet so that could be gummed up too.
HOW TO TEST FUEL
FOR ETHANOL
On a test tube or olive bottle six or seven inches long, make a permanent line about two inches from the bottom.
Fill with water to this line, then fill the tube to the top with gasoline.
Cover the tube, agitate it, and let it stand.
The ethanol and water will mix and separate out together. If the water level appears to have increased, the fuel contains ethanol and should not be used. Ethanol percentages of less than 5% can sometimes give a reading below the line. Therefore, any deviation in the water line indicates the presence of ethanol and should serve as a basis for rejecting the fuel.
HOW TO TEST FUEL
FOR ETHANOL
