I'm curious to know if anyone has a 12v battery setup other than the typical, single deep cycle marine battery for trolling motor and electronics? If so, what do you have and how has that worked for you?
My boat (see sig.) struggles with the 9.9 motor and a decent load in the boat. The 9.9 Merc (75 lbs.), transom trolling motor, group 24 battery (40+ lbs.), fuel tank, me (175 lbs.), my 2 yr. old (30+ lbs), my 6 yr. old (50+ lbs.), and a canvas tote of snacks and water bottles cannot get us on plane. I maxxed out at 12 MPH when we went for a ride yesterday and the bow was high. I was adjusting the trim of the motor and moving my 6 yr. old one seat forward (to the very front seat) gained us 2 MPH and brought the bow down a little. I think that the motor was mounted a little high, so I raised it 1" (following guidance on how to mount a motor) once we were home; I still need to test this setup. I think it could stand to go up another 1" but I'm out of transom to clamp on; I would have to look into a jack plate.
Either something is wrong with the motor (I detect nothing wrong) or think I have too much weight in the stern. A different battery setup that is moved forward would probably offer the biggest improvement for the least dollar investment. I do not have storage compartments other than a cavity under the front seat. I would need to make some modifications but I can already see that a typical Group 24 will be difficult to fit. I'm curious if anyone has used batteries like this:
12v 12AH SLA battery
https://www.ebay.com/itm/131151090450?s ... 1438.l2649
You can buy these in a lot of places so the above battery is just an example. There are other models with varying amp hour ratings. My existing Group 24 interstate battery is 58AH. Five of these 12 AH SLA batteries wired in parallel would give me 12V at 60AH, and would offer more flexibility with mounting (due to their size). They should be able to hide in that front seat and not affect much, if any, flotation. My group 24 battery is 4 years old at this point, so I may be needing a new battery soon anyway. The cost of 5 SLAs vs. the cost 1 group 24 is around the same.
The other option I have found is a Tracker Lithium:
https://www.basspro.com/shop/en/tracker ... ne-battery
The Group 24 battery weighs 15 lbs. The cost is extreme and that 15 lbs. would still be in the stern.
There are other more extreme options - covert 9.9 to a 15HP engine, or new/different 15HP engine (Tohatsu has a 95 lb. 15HP 4-stroke now). Both options are expensive. I keep coming back to that a different battery arrangement would benefit the boat no matter what engine is on it.
Anyway, just trying to think out loud and out of the box. Thanks for any input!
