Jamesd4801
- Joined
- Jul 25, 2020
- Messages
- Reaction score
- 1
on a 9.5hp Evinrude, the timing mark on the armature doesnt line up with the mark on the cam marked TOP. With the lining up points off the "O" in TOP on cam, the timing tool says it is advanced on the timing mark on armature, When you line up the points with the timing tool and the armature plate the cylinder is not at top dead center it is early.
Any suggestions on what to do? I have great spark at 1/4", it is getting fuel as plugs are wet. Good compression on both cylinders
