On Board chargers -
Trolling motors, Fish Finders, GPS, Batteries, anything Electrical, post it here.
the hammer
15
On Board chargers -
Post by the hammer »
Are they worth it?
I have two portable chargers for my three batteries that I use before my trips. I see a lot of dissatisfaction with on-board chargers.
One of my portable chargers is on it’s last legs, should I just by another or is an onboard charger worth it?
Thanks
MN Fisher
On Board chargers -
Post by MN Fisher »
the hammer wrote: 24 Oct 2021, 10:47 Are they worth it?
Thanks
Another board I'm on - the recommendation is to stick to these three brands.
Pro Mariner
Noco
Minn Kota
I'm actually looking at a Noco for the F-9 rebuild
MrGiggles
4
On Board chargers -
Post by MrGiggles »
If you're just charging one battery, not really. It's easy enough to rig up a quick connect harness. Get a digital charger that's at least 4 amps and run with it.
It's when you're charging 2 or more that they become worth it IMO. Each battery gets topped up and charged equally, without the hassle of swapping a charger around.
Battery chargers as a whole seem to be unreliable nowadays. I've had a Promariner for almost three years now and it's been fine. I only leave it plugged in long enough to charge fully and then unplug it. I think leaving them plugged in is a mistake.
the hammer
15
On Board chargers -
These chargers stay on your boat or are they attached to your garage wall?
MN Fisher
On Board chargers -
Post by MN Fisher »
the hammer wrote: 24 Oct 2021, 17:35 These chargers stay on your boat or are they attached to your garage wall?
Mount them in the boat - run an extension cord to the socket.
the hammer
15
On Board chargers -
MN Fisher wrote: 24 Oct 2021, 17:58
:beer:
LDUBS
5
On Board chargers -
Post by LDUBS »
MrGiggles wrote: 24 Oct 2021, 11:25 If you're just charging one battery, not really. It's easy enough to rig up a quick connect harness. Get a digital charger that's at least 4 amps and run with it.
I have a Minn Kota precision charger for the TM battery. I usually plug it in as soon as I get back from the lake and leave it. Minn Kota says I can leave the charger plugged in. Says it will stop charging when the battery is full then go into some kind of monitoring mode. I sure paid enough for the thing, so I hope they are right about this.
For the starter motor I have a small Noco. I usually plug it in the day before I'm heading out. I just want to make sure I have enough juice to turn the motor over a couple times.
The Minn Kota charger weighs something like 4 - 5 pounds. The small Noco weighs next to nothing.
Have Rod - Will Fish
MrGiggles
4
On Board chargers -
Post by MrGiggles »
LDUBS wrote: 24 Oct 2021, 22:59
Yeah, they are made to be plugged in 24/7. I just think it's a mistake because you're leaving them open to power surges, lightning, stuff like that. There's a lot of sensitive electronics in there.
the hammer
15
On Board chargers -
I got a feeling I would rather buy a new charger and play musical batteries than to go with an on-board charger. I’ve read too many horror stories with the reviews for even the best brands. Even if you figure 90% were user related, I’ll be an old man about it charge manually. I’m sure that’s what Hank Hill would do!
LDUBS
5
On Board chargers -
Post by LDUBS »
the hammer wrote: 25 Oct 2021, 07:46 I got a feeling I would rather buy a new charger and play musical batteries than to go with an on-board charger. I’ve read too many horror stories with the reviews for even the best brands. Even if you figure 90% were user related, I’ll be an old man about it charge manually. I’m sure that’s what Hank Hill would do!
"I’m sure that’s what Hank Hill would do!"
Good enough for me!
LDUBS
5
On Board chargers -
Post by LDUBS »
MrGiggles wrote: 25 Oct 2021, 07:10
Good point. Mine doesn't set for long period of time unused. I think I might change my habits.
GYPSY400
Re: On Board chargers -
Post by GYPSY400 »
I have an on board charger for the battery under a front casting deck because it's a pain to get at the battery terminal and/or remove the battery.
Sent from my SM-A526W using Tapatalk
