Charging batteries
- 15
Charging batteries
Okay, I charged my batteries and went fishing. All is fine.
So, should charge the batteries again after using and charge again before fishing OR just charge before fishing again?
Thanks
Thanks
Charging batteries
I always charged my batteries the night before fishing. Now I have a box with a meter, so I may just let it go until the meter says to charge. I'd like to run the battery way down the first couple of times. Don't know if that is a good thing or just an old wives tail. But that is what I do. YMMV.
1974 12' Eldo-Craft
1978 12' Rich-Line
1978 12' Rich-Line
Charging batteries
My standard with the canoe was to plug in the charger the night before a trip...probably do the same with the F-9.
Current project:
1972 Alumacraft F-9 Lake Master
- 1
Charging batteries
For lead acid batteries, it is usually recommended to charge after use to help prevent sulfation and only store with a full charge.
I charge my batteries as soon as get back from fishing/camping, when batteries are fully charged I switch to a maintenance charge.
- 4
Charging batteries
After a trip, I will plug in the charger and unplug it in the morning once it's done. That's it. None of my electronics draw power when powered off, so discharge from sitting is very, very minimal.
Only if you let them sit for months should you need to recharge before heading out again.
- 5
Charging batteries
InSaneFisherMan wrote: ↑27 Oct 2021, 17:00 For lead acid batteries, it is usually recommended to charge after use to help prevent sulfation and only store with a full charge.
I read somewhere, probably here on TB, that is the best practice. I also plug mine in as soon as I get the boat back home.
Have Rod - Will Fish
- 15
Charging batteries
I’m not running my batteries on a charger though. Mine are sitting in the boat until the next trip. I’ll charge them the day before my trip.InSaneFisherMan wrote: ↑27 Oct 2021, 17:00 For lead acid batteries, it is usually recommended to charge after use to help prevent sulfation and only store with a full charge.
Re: Charging batteries
Yes it is best practice.. sulfated batteries loose capacity and will fail sooner. Best thing to do is plug into a charger as soon as you get home, and then top up the charge before you leave next time.LDUBS wrote:InSaneFisherMan wrote: ↑27 Oct 2021, 17:00 For lead acid batteries, it is usually recommended to charge after use to help prevent sulfation and only store with a full charge.
Sent from my SM-A526W using Tapatalk
Why do you ask what to do if you already have your mind made up on what your going to do?the hammer wrote:I’m not running my batteries on a charger though. Mine are sitting in the boat until the next trip. I’ll charge them the day before my trip.InSaneFisherMan wrote: ↑27 Oct 2021, 17:00 For lead acid batteries, it is usually recommended to charge after use to help prevent sulfation and only store with a full charge.
- 15
Charging batteries
GYPSY400 wrote: ↑15 Nov 2021, 18:30Why do you ask what to do if you already have your mind made up on what your going to do?the hammer wrote:I’m not running my batteries on a charger though. Mine are sitting in the boat until the next trip. I’ll charge them the day before my trip.InSaneFisherMan wrote: ↑27 Oct 2021, 17:00 For lead acid batteries, it is usually recommended to charge after use to help prevent sulfation and only store with a full charge.
My mind wasn’t made up until I saw a couple of resonses
- 8
Charging batteries
My boat sits in the water from late March through Oct usually. I have no electronics but the bilge pump runs when it rains and it has power trim. I will top the battery off with the charger once or twice during the season. When the boat is put away in the garage for the winter, I pull the battery out and put it in the basement with a full charge (I will typically put the charger back on it before the first use of the new season). You really shouldn't need to charge it very often since the motor will maintain the charge while it's running (but that can depend on the amount of electronics you have/use in the boat).
2001 Lowe Roughneck 1652 VT with Merc 60/45 jet 2 stroke
- 1
Charging batteries
My trolling motor doesn't charge my deep cycle battery and my DF9.9 manual says not to connect to deep cycle batteries.
Starter batteries may not need charging, but batteries used on trolling motors will need charging if used.
- 4
Charging batteries
Yep. Especially with older two strokes that have dismal charging systems. Most are 10 amps or less running wide open. In a typical fishing scenario that doesn't amount to much at all.InSaneFisherMan wrote: ↑21 Nov 2021, 20:40My trolling motor doesn't charge my deep cycle battery and my DF9.9 manual says not to connect to deep cycle batteries.
Makes me appreciate my 90hp 4 stroke that has a full blown alternator, capable of putting out a decent charge even at idle.
- 1
Charging batteries
One simple way to determine lead acid battery charge status is a DC voltmeter and status of charge chart for flooded batteries. The battery should be rested, not charged/discharged for a minimum of 15 minutes.
Checking specific gravity of each cell would be another method, but this method is very difficult when fishing.
Sealed lead acid batteries can be checked with a DC voltmeter but may require a different charge chart.
Top display is starter battery and bottom trolling motor.
- 5
Charging batteries
Assuming I attached them properly, here are a couple of blogs from Minn Kota about battery charging/maintenance. Of course they promote their products, but still there might be some helpful info here related to this thread.
https://www.minnkotamotors.com/blog/art ... aintenance
https://www.minnkotamotors.com/blog/art ... le-battery
