'67 14' Alumacraft Shallow V and Trailer remodel.
Boating related questions, small projects, custom work and talk go here.
seaarc
Post by seaarc »
WOW! Ask and you shall recieve great detailed pics and explanations. Thanks. One question I have is about the drain line, I thought it needed to go out the boat above the water line. That could be why the overflow is not keeping up with the pump. Great work on the boat man and thanks for the ideas.
Dave
Image Image Image Image Image
Tunnels
Post by Tunnels »
Thanks for the pictures. I see me making sidewall braces as you did 7 covering them with 1/4" ply & carpeting. Behind the ply is a good spot for floatation.
"Life is tough, but it's tougher if you're stupid."
-Sgt. John Stryker
Hanr3
Post by Hanr3 »
Thanks and your welcome.
I also suspect you could be right about the drain. I did whack another 1" off the top to gibe me more time before it overflows. It could also be that the overflow drain is 3/4", too small. I can still and might put in an overflow drain at the top, put in a tee and connect it to the main drain. Then I just need a plug for the lower drain. That will be easy enough to make, whack off the tube close to the bottom and put a pvc cap on it.
Tunnels, great idea to add extra floatation. I might have to use that idea.
HOI Crappie Club
Where family and friends come to compete for a little more than bragging rights.
'97 16' Sylvan Back Troller Select
'67 14' Alumacraft
'57 Model FD11 18-hp Johnson Seahorse
'09 Traverse FWD V6 w/ towing package, power sun and moon roof, and ton of other options. The only one I wanted was the towing package. :mrgreen:
INGrandad
Post by INGrandad »
Wow, I been so busy collecting ideas for my flatbottom I hadn't looked at v-mods. This is like an episode of extreme makeovers. Way, way past my level of expertise. Nice job.
Stryker777
Post by Stryker777 »
Great thread. Thanks for posting. I am about to start modding my '73 semi-V. Just stripping it and repairing right now, but have a good idea of what I want to do to it after seeing this thread.
1+1=10
Hanr3
Post by Hanr3 »
Alrighty folks were are almost done. I took it out today for a second round of testing. I didn't get to spend too much time on the water. However the boat works great, however there are a couple of things I need to adjust.
HOI Crappie Club
'67 14' Alumacraft
shizzy77
Post by shizzy77 »
looks great! Im jealous!!! :D
'68 Alumacraft FD "The Sea Monkey" , '65 Johnson 6HP
kemical
Post by kemical »
i was going to say the same thing " sooo jelous"" lol
i have a 12 i wish i had the space on a 12' like your 14'
but i think i will do the same floor , i dont use a livewell so i think ill have enough space for 3 seats..with a front TM (foot controlled)
right now it has 3 benches,, ill take them off! and us low pedestals
same setup but i want to be able to have my TM portable (to take it off and on) soo when there are three people i can take it off and use a hand controlled front TM , and if theres 2 people then i can put on the foot one TM
still trying to figur out how i can modified the front there isnt enough space to put the mount on so i have to rig someting up,,
i tried once with wood and brackets and my TM started to get lose and it broke the bracket that was holding the TM and i had to paddle the whole time,, (sucked huevos) that day,,
BUT OVER ALL YOU DID AWESOME JOB!!
https://www.facebook.com/tcmdoc
Tampa, fl
IN THE HUNT LOOKING FOR A JON!!
Hanr3
Post by Hanr3 »
Well I have managed to get out on the water several more times, even took the wife once and we got poured on.
Below are some more pics to highlight my last couple of mods.
On to some night shots.
There were a couple of things pointed out through out the build thread.
I did move the rear seat back as far as possible and have debated putting it on the floatation box. Good catch Baptistpreach....
Baptistpreach also had questions about my switch panel location and someone was concerned about my circuits shorting out in the rain due to the location of my connections. I mentioned eralier that the wife went with me one night. We got dumped on. Rained, thunder, lightening, rained, rained and did I mention it rained. The boat did great. No electrical shorts, all the switches, electrical circuits worked perfect, and I even got to use the bilge pump for about 3 seconds.
After rereading the whole thread I have some general comments to add.
I ended up buying 3 more linear feet of carpet and wished I would have bought a half gallon instead of the three pint cans. I ended up useing about a gallon of contact cement overall.
I used trailer wiring for my general light circuits. Its color coded wire, 25' goes for about $12 and it comes with 4 wires connected together. Hard to pass up the price of $12 for 100' of wiring.
I picked up a new lawn garden 12v battery and ShipN Shore battery charger for the boat. The battery was $28 with a core, and $10 off with a rebate.
The charger is regularly $60, on sale for $40, and has a $10 rebate. So I bought them both. Glad I did.
I used MikeA idea of the eye bolts, instead I used them to anchor the batteries instead of the livewell.
I decided not to add any support to the port side. I figured the floor is anchored front and back so the boat will never buckle, the front deck spreads teh gunwalls up front and the rear floatation strengthens teh rear gunwalls, plus the two storage boxes int eh rear are also anchored to botht eh gunwall and floor. There pretty solid. Plus I watched the gunwalls while under power, no flex in them at all.
I did lower the overflow the 1" and it made a huge difference. Teh pump still exceeds the drain capacity, however I have at least a minute or so to catch it. Shouldn't be a problem, I have to manually turn the pump on and off and you can hear it run.
I did get teh main motor to run and the boat moves along nicely. It almost gets up on plane. Although I think I need to rebuild the carb, she isn't winding out (hitting the rpms) like she should.
For those looking at my livewell connections, there are no clamps on the pipes and they dont leak, yet. I have the clamps, just need to put them on.
As of right now I am very satisfied with the boat and how she turned out. Showed it to my wife uncle, the one who sold me the boat, and he was impressed with the mods. Now my biggest problem is putting fish in teh boat and that ain't the boats fault. :mrgreen:
I did manage to catch another dink.
HOI Crappie Club
'67 14' Alumacraft
rcgreat
Post by rcgreat »
Awesome build. Turned out fantastic. I hope mine turns out half as good
baptistpreach
Post by baptistpreach »
I definitely love your finished product. Many many very good practical ideas. I'll probably incorporate the one about the buoys/ drinkholder, very nice.
Living proof that anyone can, if they just try.
If you don't see me here, I might just be out on Visitation!
Hanr3
Post by Hanr3 »
baptistpreach wrote:I definitely love your finished product. Many many very good practical ideas. I'll probably incorporate the one about the buoys/ drinkholder, very nice.
:LOL22:
Thta's my favorite mod too. :mrgreen:
HOI Crappie Club
'67 14' Alumacraft
LarryA
Post by LarryA »
Looks great. Real nice work!
dougdad
Post by dougdad »
awsome job hanr, looks great.
Just Fishen!!
USAF Retired.
LMNAHC
MikeA57
Post by MikeA57 »
Hanr3, I hadn't been back out here in a while to check out your progress and it's really come along nicely. I'm glad I was able to suggest something you were able to use. You really made the most out of the space you have available.
That boat is very much like the 14' Alumacraft I grew up fishing in. You said you like to fish off the port side, yet your seat in the back in on the starboard. Does that present any problems for you? I like to be close to the side that I'm fishing off of. I just feel like I have a better command of the situation over there.
