OK so I believe I have settled on a boat, now time for the power. My first purchase will be a trolling motor for the back of my boat. I am going to go with the most thrust I can afford. My question is the battery.
I know that I have to buy a battery, BUT do I or should I also purchase some type of charger for the battery?
I have printed out a previous thread about batterys but there is very little info on charging or notcharging.
I am so sorry if these questions are simple, I just have very little idea on the whole thing and I thought it would be just easier to ask a question than to reread things I have found on the Internet.
Thanks in Advance
Trolling Battery
- 14
- 15
- 14
- 14
I am going to have to go look at my battery, as I forget what brand it is and the specs. It is an AGM type so it is no spill, deep cycle, and it was in the $100 range, which is less then the popular Optima version.
My charger is an old Sears 4 amp. Nothing special. It does take a whole day to charge the battery though so when it quits working I will get something better.
Matt
- 15
On the battery, look for a marine/deep cycle battery for the boat, which is designed to be charged, then drawn way down over and over without damage to the battery. A standard car battery will not last more than a few cycles like this, they are designed to used, then topped off immediately.
As far as a charger, get the largest charer you can afford, and make sure it's an automatic charger. Always charge your batteries as soon as you get done, so they are ready for the nex trip. If you get an automatic charger, you can leave the charger hooked up to the battery without harming it, it will automatically turn itself on and off, to keep the battery full.
- 14
As Stirling stated get a deep cycle battery. the AGM ones tend to run a bit more than the lead acid on the cost effective side the AGM say they will last for up to 10 years as opposed to the 3 or 4 from acid I don't use agm so I wonder about the life span also be sure if you get an AGM you get the proper charger it will say it can charge AGM batteries on the box. and as soon as you get hoe hook up the charger that will help them last longer also.
If you are getting a charger get one that is at least 10 amps it will help if you go away for the weekend and plan morning and afternoon fishing outings you can get almost back to 100% charge in a few hours
Wayne
Wayne
emoticon-tv-002
WE'RE ON A MISSION FOR GOD
- 14
As stated above, go with a deep cycle/marine battery. As far as your charger, I recommend the Guest brand (good chargers, good customer service), and yes I'd go with at least a 10 amp. You can leave the charger hooked-up, but if using a lead-acid battery you still need to check the water levels occasionally, and use distilled water (I find mine at WalMart) to fill them with.
- 15
- 14
fill, add, just a matter of semantics and which county you're from, loldampeoples wrote:There's another thing - you don't fill your batteries with water, you just add to it if neededNot 100% sure, but it only needs to be about 1/4" or so above the plates, any more and you'll have constant leakage problems.
Where I live we use warsh rags, while others somewhere else might call them wash cloths.
- Site Admin
- 15
- 15
I know it, but after he filled his batteries, his next question would be why is it leakingWaterwings wrote:fill, add, just a matter of semantics and which county you're from, loldampeoples wrote:There's another thing - you don't fill your batteries with water, you just add to it if neededNot 100% sure, but it only needs to be about 1/4" or so above the plates, any more and you'll have constant leakage problems.
