Primer On Old Outboards
bassboy1
Post by bassboy1 »
I have seen that numerous times before (with about 8 different people claiming to have written it nonetheless) and it is a very good resource. See why I am an old OMC guy?
Although, being that I am more of a collector than one wanting cheap outboards, I have been in search of a 1949 - 1951 ten horse for a time now. A Chris Craft Commander 10 horse would also be great, if someone knows of one.
Doughboyracing
Post by Doughboyracing »
Thanks for posting that. Very interesting & informative read.
ben2go
Post by ben2go »
You're welcome.
Madcatters
Post by Madcatters »
Thanks for the article...
The shallow V we bought came with a 2.5 HP 1947 Sears Elgin....
We replaced it with a 1957 18HP Johnson Sea Horse for a couple of hundred dollars. Nice to know it might be an OK motor to use.
Madcatters of NC
Len, Carol, Adam & Jacob
1970 Richline shallow V
1957 Johnson Seahorse 18 HP replacing 1947 Elgin 2.5 hp outboard
Sader762
Post by Sader762 »
Good read, glad to know that my '62 Evinrude 5.5 Fisherman is a keeper. Doing a complete rebuild on it right now.
HUSKERBOATER
Post by HUSKERBOATER »
I liked that article, but have one thing to add. It says that OMC outboards 1959 or earlier have the pressurized tanks (which I have heard before). It then says that those 1960 or later all have the modern fuel pump except for the 1960 5.5hp Johnson/ Evinrude which retained the pressurized fuel line. I recently bought a 1960 Evinrude 5.5 fisherman, and started to sweat bullets after reading this because I just spent $60 getting the fuel tank and connections. I ran down into the basement and confirmed that the 1960 Evinrude 5.5 does NOT have a pressurized line. It has the one line system. Anyways this seems to be a popular model so I wonder why it would say this? maybe the 5.5 Johnson's had the only system for one more year while the Evinrude's converted to the modern system.
Pappy
Post by Pappy »
I have one of the 10hp engines you are looking for! Its a QD model. Great running condition with all the necessary service parts replaced with NOS parts. Can part with this one as I have a second one in a million pieces waiting on me to put it back into service. Am a collector also.
dougdad
Post by dougdad »
1959 mod. QD 21 10 hp. runs good, :mrgreen: cant have it sorry!! :mrgreen:
Just Fishen!!
USAF Retired.
LMNAHC
wis bang
Post by wis bang »
Madcatters wrote:Thanks for the article...
I still have my pappy's '47 elgin 2.5. It worked well the last time it was used and was put away after being run out of fuel. I just recovered it from my dad's stuff, it has compression and the gas tank is not rusted...I have to check the spark...
'69 Alumacraft 'Crapie Jon" - Started fishing again...Pappy spoiled me by taking me to Canada in the 60s...he was Herter's best customer!
I wish he could have seen the tackle we use now!
He used to build wood boats, he'd like to see what we now do w/ tin!
gottafish
Post by gottafish »
Bassboy1 go to https://www.smalloutboards.com I don' tknow if the motor your looking for is there but they have a bunch of antiques for sale. They also fully restored.
hossthehermit
Post by hossthehermit »
gottafish wrote:Bassboy1 go to https://www.smalloutboards.com I don' tknow if the motor your looking for is there but they have a bunch of antiques for sale. They also fully restored.
Another really good resource for old outboards is AOMCI, antique outboard motor club international or sumpin like that. Good bunch of people there, actually think they are the ones that steered me over here.
EAT PIE. IT’S GOOD. (AND,GOOD FOR YER SOUL)
(Chocolate Cream is Best)
I’d rather be rich than stupid. (Unfortunately, I wasn’t given a choice)
I bet one legend that keeps recurring throughout history, in every
culture, is the story of Popeye
another Hillbilly
Post by another Hillbilly »
This link goes directly to outboard manuals, great share thanks. www.outboardbooks.com
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote." Benjamin Franklin,1759
"Farming looks mighty easy when your plow is a pencil and you're a thousand miles from the corn field." Dwight D. Eisenhower
"Those who hammer their guns into plows will plow for those who do not.." Thomas Jefferson
KillerKilgore
Post by KillerKilgore »
I have a 58 10hp Johnson QD-19. (sorry it's not for sale) It has a pressurized fuel tank. it also has a bad impeller. currently in the process of fixin that.
anyway. on the tank there is a prime pump. if that fails or is leaking. you could be in trouble.
I put an in-line prime pump on the fuel side.
then took some gasket material and made a 2 new gaskets for the tank.
IMPORTANT!!!
if anyone does this be sure to use the old gaskets as a guide and cut ALL holes in the new gasket that the old gasket has. because there is a pressure release valve on it that vents to the outside of the tank if the tank builds up too much pressure. too much pressure in the tank is a very bad thing.
the pump on the tank no longer works but is there for looks (also so I lose it) but the in-line primer pump does.
the engine stills runs great and doesn't know the difference and the tank can be put back original if I want to.
KillerKilgore
If you can read this, Thank a Teacher.
If you can read this in English, Thank a Vet.
If you can read this in the dark, Thank a Coal Miner.
All electronics run on SMOKE.
Auzivision
Post by Auzivision »
Based on recomendations found in this link, I decided to pick up a 1973 Johnson 6hp to pair up with a 12' Sea King. Since this isn't going to be a trailer boat, I wanted to get an engine light enough to carry by hand.
Haven't seen it run in person (still need a fuel tank) but according to the marina everything checks out good... pumping water, good spark, good oil with compression at 92 & 95 psi. They replaced the plugs, gear oil, and ran through some decarb last fall.
Looks like a pretty low hour unit with just a few scatches here and there. Found it on CL for $300 and the guy threw in a couple needed oars for free.
Auzivision's 12 foot Sea King project - https://www.tinboats.net/forum/viewtopi ... =3&t=25002
