nicdicarlo
Ok, I've got my Crawdad gutted and cleaned out. Now its time for the new floor and a few other upgrades. One of which will be electrical. I want to store my battery, or hopefully batteries, in the back, either under the seat or under the back deck if I rip out some foam. I plan on mounting conduit on the starboard side, running to the front area to house my TM cable and Depth Finder cable. The TM is a 27lb transom, converted to a bow mount, minn kota with a big foot control. I think I'll be ok with making the connections for the DF. My plan is house a permanant TM cable in the conduit with connections for the battery in the stern and a connection to mate with the exisiting TM cable in the bow. My question is, what is the best, and safest, way to make this connection? Keep in mind, this is a connection that will have to be disconnected at the end of the day to remove the TM. Also, what type of cable do you guys recommend? I don't want to rob any more power than is absolutely necessary. Thanks for your help.
