- Joined
- Oct 29, 2023
- Messages
- Reaction score
- 7
- LOCATION
- Gilberts, IL
I bought my first boat last October. I did not notice at the time but there is flex in the transom so I think I should replace the wood but the engine height also look a lower than ideal.
The bottom bolt holes for the engine do not go through the wood part of the transom.
I would have to drill a new bottom holesto raise the engine but that would allow it be put in the wood section of the transom.
I was thinking I could raise it two hole locations at the top which would be about an 1 1/2 inches.
It does not look like it would be that bad to replace the wood in the transom. The corner cap un screw revealing the wood. I probably want to get a cherry picker for the engine.
Its a 1990 Lund Rebel so may not be worth the effort but it has a newer 4-stroke 30HP Tohatsu with power tilt plus a newer Minn-Kota Terrova and a Garmin 73sv fish finder.
Does this seem reasonable to tackle. Its probably not going to fail any time soon but it bugs me.
