Top speed!!!
shawnfish said:
Vermonster said:
Motor: 1979 Evinrude 15
Hull: 1972 Richline Sportsman
Prop: Stock
Mods: Plywood/Carpeted Seats and Floor, Extended front deck with aluminum frame, low back seat.
Weight: 606 Total
126 hull
50 mods
50 battery
25 trolling motor
75 motor
40 gas
40 gear
200 me
Plane Time: 5-8 seconds
Top Speed: 25 (not WOT) - likely 27 in calm water
what gear ratio is your motor? how are you reading your speed?
Likely whatever stock is... Not really sure - I've done nothing since I got it last summer and I don't think the original owner tinkered with it. As for reading the speed, I used a Garmin GPS.
Motor: Suzuki DF20A
Hull: 2015 Tracker Topper 1436
Prop: Solas 9.25X11
2nd highest trim setting due to some hook in the hull.
Weight: 665
165 hull
200 me
40 OTF Electric Jack Plate
50 Battery
40 Gear/Tackle Box
50 Plywood
120 Motor
Misc 20
Plane Time: 5-10 seconds depending on motor height
Top Speed: 28.2 up and down river in calm water with just me. 29 in chop. With another 200-230lbs person, about 26/27mph.
WOT RPM: 6140-6250 depending on motor height and load.
Likely won't break 30 without a prop change or without some more ballast in the rear.
