12 Ft Ouachita V Hull ,,,,Making it Mine.
<blockquote data-quote="Weldorthemagnificent" data-source="post: 448950" data-attributes="member: 22139"><p>Pretty common problem once weight is added. A hydrofoil will give you the necessary transom lift. I’ve had several 14’ boats that wouldn’t plane with 20-25 hp after mods and the hydrofoil stabilizer fixed them. Easy on plane, able to throttle back once on plane. Cheap fix and better than ripping your hard work apart. </p><p></p><p></p><p>Sent from my iPhone using Tapatalk</p></blockquote><p></p>
[QUOTE="Weldorthemagnificent, post: 448950, member: 22139"] Pretty common problem once weight is added. A hydrofoil will give you the necessary transom lift. I’ve had several 14’ boats that wouldn’t plane with 20-25 hp after mods and the hydrofoil stabilizer fixed them. Easy on plane, able to throttle back once on plane. Cheap fix and better than ripping your hard work apart. Sent from my iPhone using Tapatalk [/QUOTE]
