1442 G3 Modification
sjbs07
Started a project nearly complete 2010 G3 1442 jon boat. I first build a custom 24 gallon livewell with freshwater pump-in and recirc pump. Made from .090 aluminum all welded seams. The boat had no built-in livewell and I wanted to maintain the floatation where most people cut out the seats and install the livewells. Next I framed the boat in cedar 1X4 supported with 1X1 aluminum angle sealed the wood with several coats of spar varnish. Then plywood with serveral more coats of spar varnish. Installed a fuse panel and toggle switch panel for pumps and nav lights.
    51.7 KB
    66.1 KB
    33.9 KB
    32.9 KB
    28.7 KB
I fabricated the livewell at work only cost was fittings and pumps. I ordered all my fittings from Flow-Rite.
updated pics of finished project
    142.2 KB
    111.9 KB
    68.6 KB
ChitownBasser said:
"A real crackhead" Just a quick pic I had for an avatar.
Almost reminds me of the crackhead on the episode of the Sopranos where Tony is checking out a neighborhood where they bought houses to gut the copper pipe, etc...the one where AJ says..."So that's a crack ho!" LMAO
