1456 landau mod
<blockquote data-quote="FLminnow" data-source="post: 206273" data-attributes="member: 6083"><p>Steel flex has arrived. Now, anyone have any advice on sand paper grit for the job? I will be using an 8" orbital sander and a dremel multimax for the tight corners. And im assuming any acetone will do the job for clean up after sanding and blowing it off. Thanks for any ideas.</p></blockquote><p></p>
[QUOTE="FLminnow, post: 206273, member: 6083"] Steel flex has arrived. Now, anyone have any advice on sand paper grit for the job? I will be using an 8" orbital sander and a dremel multimax for the tight corners. And im assuming any acetone will do the job for clean up after sanding and blowing it off. Thanks for any ideas. [/QUOTE]
1456 landau mod
