15' Starcraft jet
<blockquote data-quote="JMar650" data-source="post: 160178" data-attributes="member: 3497"><p>It's been going kind of slow due to crappy weather and working on other projects around the house. But I have managed to paint the inside of the boat gray and doing some blue trim at the moment. Couple things I've learned so far: no matter how big your garage is you always want more room, the marine grade epoxy (same stuff Bobberboy used) is the best thing I've found for filling in old bolt holes in the hull, and if you mix enamal hardener in paint you need to use it that day or you get</p></blockquote><p></p>
[QUOTE="JMar650, post: 160178, member: 3497"] It's been going kind of slow due to crappy weather and working on other projects around the house. But I have managed to paint the inside of the boat gray and doing some blue trim at the moment. Couple things I've learned so far: no matter how big your garage is you always want more room, the marine grade epoxy (same stuff Bobberboy used) is the best thing I've found for filling in old bolt holes in the hull, and if you mix enamal hardener in paint you need to use it that day or you get [/QUOTE]
15' Starcraft jet
