Motors
1956 Evinrude Modification
<blockquote data-quote="Ouachita" data-source="post: 116828" data-attributes="member: 186"><p>Not sure about the 56' 10hp but I did a fuel pump conversion with at 58' Johnson 18 hp. I just took off the bypass cover and fuel pump for the 66' 20hp and put it on the 58' 18 hp and never had a problem. Someone here may know if there is an equivalent match for your motor with a 60's model with a single line fuel setup. Good luck with the motor. Those old Johnsons/Evinrudes are so cool looking and will last you forever if they are maintained.</p></blockquote><p></p>
[QUOTE="Ouachita, post: 116828, member: 186"] Not sure about the 56' 10hp but I did a fuel pump conversion with at 58' Johnson 18 hp. I just took off the bypass cover and fuel pump for the 66' 20hp and put it on the 58' 18 hp and never had a problem. Someone here may know if there is an equivalent match for your motor with a 60's model with a single line fuel setup. Good luck with the motor. Those old Johnsons/Evinrudes are so cool looking and will last you forever if they are maintained. [/QUOTE]
Motors
