Motors
1957 Evinrude 10 hp -- Won't start
<blockquote data-quote="Piomarine" data-source="post: 407574" data-attributes="member: 16014"><p>I went ahead and just drained and replaced the oil with HPF Pro as you suggested. I also found a parts dealer about 20 minutes from me that carries basically every OEM part I could ever want for this motor and got 2 new drain seals. I pulled the old ones and they were very badly worn out. The oil had likely been changed in the last couple years but the rings most certainly had not. They were badly compressed and one was cracked.</p><p></p><p>I'm going to take it out tomorrow and I'll recheck the oil that night to see if it was in fact the bad rings or if it will need further attention.</p></blockquote><p></p>
[QUOTE="Piomarine, post: 407574, member: 16014"] I went ahead and just drained and replaced the oil with HPF Pro as you suggested. I also found a parts dealer about 20 minutes from me that carries basically every OEM part I could ever want for this motor and got 2 new drain seals. I pulled the old ones and they were very badly worn out. The oil had likely been changed in the last couple years but the rings most certainly had not. They were badly compressed and one was cracked. I'm going to take it out tomorrow and I'll recheck the oil that night to see if it was in fact the bad rings or if it will need further attention. [/QUOTE]
Motors
