1958 Lonestar Holiday bowfishing/hunting conversion
<blockquote data-quote="josher3006" data-source="post: 280210" data-attributes="member: 8793"><p>Worked on the boat over the weekend. Finished cutting and fitting the front deck, and rear bench seat. First made a template out of cardboard box from a water heater. Cut out the plywood parts, then sealed the plywood with two coats of epoxy. When the second coat of epoxy was still tacky I sprayed some sand in it with the sandblaster to make it non-skid like the floor. After that I shot it with a couple coats of the mixed rustoleum. As that dried, I used a scotchbrite pad to rough up the inside gunnels that would show after the deck was put in. Then I shot on a couple of coats of dead grass ultra flat paint. I got this at my local Gander Mtn. it is made by hunter's specialties, and compares to the Parker duck boat paints a lot of people use, but it is cheaper. Here are some pics</p><p></p><p><a href="https://rides.webshots.com/photo/2381185160065863660XraCoZ" target="_blank"><img src="https://inlinethumb28.webshots.com/51995/2381185160065863660S600x600Q85.jpg" alt="" class="fr-fic fr-dii fr-draggable " style="" /></a></p><p></p><p>Front deck non-skid'd and painted</p><p></p><p><a href="https://rides.webshots.com/photo/2942785710065863660kIusKR" target="_blank"><img src="https://inlinethumb43.webshots.com/52394/2942785710065863660S600x600Q85.jpg" alt="" class="fr-fic fr-dii fr-draggable " style="" /></a></p><p></p><p>Rear bench non skid'd and painted, and the front part of the front deck --it had to be done in two pieces</p><p></p><p><a href="https://rides.webshots.com/photo/2438644180065863660TfsTai" target="_blank"><img src="https://inlinethumb61.webshots.com/51388/2438644180065863660S600x600Q85.jpg" alt="" class="fr-fic fr-dii fr-draggable " style="" /></a></p><p></p><p>Inside of boat painted.</p><p></p><p>Hopefully I get the seat deck plates cut out and secured, and then the floor and deck can be anchored back in sometime this week.</p></blockquote><p></p>
[QUOTE="josher3006, post: 280210, member: 8793"] Worked on the boat over the weekend. Finished cutting and fitting the front deck, and rear bench seat. First made a template out of cardboard box from a water heater. Cut out the plywood parts, then sealed the plywood with two coats of epoxy. When the second coat of epoxy was still tacky I sprayed some sand in it with the sandblaster to make it non-skid like the floor. After that I shot it with a couple coats of the mixed rustoleum. As that dried, I used a scotchbrite pad to rough up the inside gunnels that would show after the deck was put in. Then I shot on a couple of coats of dead grass ultra flat paint. I got this at my local Gander Mtn. it is made by hunter's specialties, and compares to the Parker duck boat paints a lot of people use, but it is cheaper. Here are some pics [url=https://rides.webshots.com/photo/2381185160065863660XraCoZ][img]https://inlinethumb28.webshots.com/51995/2381185160065863660S600x600Q85.jpg[/img][/url] Front deck non-skid'd and painted [url=https://rides.webshots.com/photo/2942785710065863660kIusKR][img]https://inlinethumb43.webshots.com/52394/2942785710065863660S600x600Q85.jpg[/img][/url] Rear bench non skid'd and painted, and the front part of the front deck --it had to be done in two pieces [url=https://rides.webshots.com/photo/2438644180065863660TfsTai][img]https://inlinethumb61.webshots.com/51388/2438644180065863660S600x600Q85.jpg[/img][/url] Inside of boat painted. Hopefully I get the seat deck plates cut out and secured, and then the floor and deck can be anchored back in sometime this week. [/QUOTE]
