Motors
1977 Johnson 85hp lower unit compatibility
<blockquote data-quote="PGRChaplain" data-source="post: 338503" data-attributes="member: 12412"><p>See if you can adjust the shift rod inside the Lower Unit. It needs to pull the shift rod higher, move the clamp bracket lower.</p></blockquote><p></p>
[QUOTE="PGRChaplain, post: 338503, member: 12412"] See if you can adjust the shift rod inside the Lower Unit. It needs to pull the shift rod higher, move the clamp bracket lower. [/QUOTE]
Motors
