1989 17' tracker pro 17 mod
<blockquote data-quote="KevinWI" data-source="post: 236081" data-attributes="member: 7422"><p>Solid setup....</p><p>Only thing I can see that could be incorrect would be that even though he has two 3/4" overflow lines they are both connected together using 3/4" pipe....which means the same rate of flow drain from one as both. (i.e. using two is the same as only having one as 3/4" can only handle so much water flow fed by gravity). The pipe downstream after the bottom drain would need to increase to a larger size like 1 1/2" to make it drain faster...which is the reason you have two overflow lines to keep up with the 3/4" intake from the pump. JMO.</p></blockquote><p></p>
[QUOTE="KevinWI, post: 236081, member: 7422"] Solid setup.... Only thing I can see that could be incorrect would be that even though he has two 3/4" overflow lines they are both connected together using 3/4" pipe....which means the same rate of flow drain from one as both. (i.e. using two is the same as only having one as 3/4" can only handle so much water flow fed by gravity). The pipe downstream after the bottom drain would need to increase to a larger size like 1 1/2" to make it drain faster...which is the reason you have two overflow lines to keep up with the 3/4" intake from the pump. JMO. [/QUOTE]
