Motors
2006 90 hp Yamaha 4 stroke
<blockquote data-quote="86tuning" data-source="post: 475407" data-attributes="member: 23006"><p>Seems that the fuel lines on many tanks are suspect nowadays due to fuel formulations. If the liner separates and fails it will block fuel flow. It should be easily diagnosed with some exploratory surgery, just cut the end off to look inside, and re-connect with a clamp if it's good. If it's separating it will be obvious.</p><p></p><p>Good luck!</p></blockquote><p></p>
[QUOTE="86tuning, post: 475407, member: 23006"] Seems that the fuel lines on many tanks are suspect nowadays due to fuel formulations. If the liner separates and fails it will block fuel flow. It should be easily diagnosed with some exploratory surgery, just cut the end off to look inside, and re-connect with a clamp if it's good. If it's separating it will be obvious. Good luck! [/QUOTE]
Motors
