3 pin Sterns pole light and base
artsmag10
Here's my question:
I bought a 3 pin stern light and three pin pole light base from Walmart (convenient).
The pole light base has 3 wires:
a black wire which goes back to the battery ground (no problem).
a gray wire which goes to the switch ( will assume this is the positive/hot wire).
Here's the problem:
there's also a blue wire. The directions read: "connect the bluw wire to the wire from the switch for the courtesy light. Use a wire connector to make the connection."
From my gang switch, I ran only the red "hot" wire-- to the pole light base. Ran a black ground wire from the battery.
What do do with the blue wire?
If I run another wire from the conrol panel, to what is it connected because I don't have any courtesy lights.
I connected just the black and blue wires, negative and hot/power -- no light.
Can I connect the gray and blue wires to the red "hot" wire?
Want to ask before trying.
Hate to make another trip to the store in order to purchase a 2 pin base and pole.
I might be wrong but I read it to mean that you wire it to be hot the same as the other light. Is there a switch on the light itself to control the "courtesy" light?
You require a 3 position switch.
If you are anchored, you have to have your courtesy light turned on but not your bow light... at least that is the law here.
DOH! I'm a Homer, I missed the stern part. I was thinking of the bow light with the light that shines down towards the deck for convenience.
