youll have to give it plenty of structural support. .063 is mighty thin- aluminum boats are made out of at least .080[url=https://www.tinboats.net/forum/viewtopic.php?p=347013#p347013 said:heron2000 » 51 minutes ago[/url]"]is 5052 .063 thick enough for floor and to build a front deck on my 1436 Alumacraft jon-
I'm researching this as well and had a question isn't .250" 1/4" and 1/8"smackdaddy53 said:Use 1/8" (.025") with braces on 10-12" centers and you will be fine. Thinner plate ends up costing you more because of all the extra bracing you need to make it solid.
.25"-1/4"Bigwrench said:I'm researching this as well and had a question isn't .250" 1/4" and 1/8"smackdaddy53 said:Use 1/8" (.025") with braces on 10-12" centers and you will be fine. Thinner plate ends up costing you more because of all the extra bracing you need to make it solid.
.125" ? But 1/8 is the best for floor decking ? So many sizes to choose from it gets confusing fast. .063,.080
OK thank you Ill go see if I can find your Build Thread[url=https://www.tinboats.net/forum/viewtopic.php?p=347067#p347067 said:smackdaddy53 » 01 Apr 2014, 12:50[/url]"].25"-1/4"Bigwrench said:I'm researching this as well and had a question isn't .250" 1/4" and 1/8"smackdaddy53 said:Use 1/8" (.025") with braces on 10-12" centers and you will be fine. Thinner plate ends up costing you more because of all the extra bracing you need to make it solid.
.125"- 1/8"
I seriously would go with .125", check out my build
i believe the alumacraft welded and grizzly boats are made from .100. its different from .125 but not that different- but a MILE away from .063.[url=https://www.tinboats.net/forum/viewtopic.php?p=347072#p347072 said:bigredxlt » Today, 14:08[/url]"]How about .10" thick? is there that much of a difference between .1 and .125?
If you have seen my build you will notice I tend to over engineer!typed by ben said:i believe the alumacraft welded and grizzly boats are made from .100. its different from .125 but not that different- but a MILE away from .063.[url=https://www.tinboats.net/forum/viewtopic.php?p=347072#p347072 said:bigredxlt » Today, 14:08[/url]"]How about .10" thick? is there that much of a difference between .1 and .125?
