I inherited a JW-13 so I've been tinkering with it trying to bring it back to its former glory. Not sure how long it has sat, but it was in fairly good condition. I changed the plugs, ensured the air intake was clear, threw a new impeller in it, changed the gearbox oil, put some fresh gas in it and fired it up. Starts first pull after it's up to temp and runs smooth as can be.
It's terribly slow though. 3mph on my shallow 14' v hull with only me (140lbs) in it. I put a tach on it to see where it's running. Idles down to 900rpm (take ~1/4 throttle to hold idle) and constant speed at max throttle is 2450rpm. Target rpm for this little guy is 4k. Something's amiss.
Just checked compression today and it's around 80psi on both cylinders. Pretty happy with that. My next thought is it's starved for fuel, so I'm considering a carb rebuild. Just wanted to touch base here to make sure I'm on the right track, or see if there's anything in particular I should do / investigate while I have the carb apart.
Still running the OEM prop for what that's worth. How do I pull some more rpm out of this motor?
