Motors
5hp briggs and startton mods?
<blockquote data-quote="Whoopbass" data-source="post: 189425" data-attributes="member: 2243"><p>Sorry about the bad joke.</p><p>I would look into getting an aftermarket header pipe and a performance air filter. Autozone used to sell nitrous oxide in 2oz bottles for around $6.00. The display was nearly empty every time I went in so the stuff has to work.</p><p>Those are the easiest things you can do and you should easily see a solid 20% boost in power. If you want to go all out then your going to have to drop your outboard off at a machine shop and that could get costly.</p></blockquote><p></p>
[QUOTE="Whoopbass, post: 189425, member: 2243"] Sorry about the bad joke. I would look into getting an aftermarket header pipe and a performance air filter. Autozone used to sell nitrous oxide in 2oz bottles for around $6.00. The display was nearly empty every time I went in so the stuff has to work. Those are the easiest things you can do and you should easily see a solid 20% boost in power. If you want to go all out then your going to have to drop your outboard off at a machine shop and that could get costly. [/QUOTE]
Motors
