62' Feather Craft Bent Hull
Jbfl 35
Found an old 62' Feather Craft. It sat for years and looks as though it make have filled with water and one of the rollers from the trailer bent the rail in the hull. Anyone have any suggestions on fixing or reshaping the bend? Id appriciate thanks John
    3 MB
    2.5 MB
    2.4 MB
    2.2 MB
Support the transom with blocks. Ensure that it is well supported. Support the bow with a block under the keel runner as far forward as it will allow without slipping off. Try standing and bouncing to jumping on the bent part. If that doesn't work you may have to use a block of wood and a sledgehammer. If you're successful, look closely at the keel runner to see if it's cracked. Its weaker now and may need a repair.
Okay, it's right under the front seat. So I'll take that out and give her a go. I'll let you know how it how I make out. Thanks again
I would saw thru the center rib (but not thru hull wall) right at the crease. Then bend it back like suggested above. After sheet metal is straight, then have the rib cut welded. I would even add a lap patch over the weld for good luck.
