SAMarine87
- Joined
- Jul 22, 2023
- Messages
- 5
- Reaction score
- 0
- LOCATION
- Yuma, Az
I have an 1982 Chrysler 15 horse outboard I bought a few months ago for $200. It is my first boat project and boat motor. The motor would only run when starter fluid was sprayed into the carb. I cleaned out the carb and ended up taking apart the fuel pump and found a torn diaphragm. After replacing it I got it to run. I noticed the water would not spray out unless in gear or throttle applied. I pulled apart the lower end and examined the water pump and in looked fairly new. After reassembling it and running it again i noticed more water pressure coming out of two ports from the lower. Is this normal pressure and is the water coming from the ports normal. Any info would help.
