Motors
9.9hp Evrinrude not spitting water when started
<blockquote data-quote="nimmor" data-source="post: 261892" data-attributes="member: 7990"><p>I have never been a fan of muffs. Go to your local walmart or other store and buy a cheap 55 gallon trash can, you can get one for around $10. Put the motor in that and fill it up. They work great on small motors like that. I usually just leave it hanging on my boat and place the trash can under the lower unit. I also have a 1" hole drilled in the bottom of the can and use a bilge plug in it. That makes it easier to drain. This will make sure you have a good water supply. If you still don't have any water coming out the pee hole something is wrong.</p></blockquote><p></p>
[QUOTE="nimmor, post: 261892, member: 7990"] I have never been a fan of muffs. Go to your local walmart or other store and buy a cheap 55 gallon trash can, you can get one for around $10. Put the motor in that and fill it up. They work great on small motors like that. I usually just leave it hanging on my boat and place the trash can under the lower unit. I also have a 1" hole drilled in the bottom of the can and use a bilge plug in it. That makes it easier to drain. This will make sure you have a good water supply. If you still don't have any water coming out the pee hole something is wrong. [/QUOTE]
Motors
