First, let me say I am an electrical ignoramous. I can rebuild a motor from the crank no problem but electrical I am clueless. I am having incredible difficulty figuring out the wiring on my 14' Starcraft with my 25hp Merc 2 stroke. Motor has electric start and there is about a mile of wire under the console which I don't understand. The original ignition switch failed on my the year before last and I have been pull starting the motor to start since then. I tried to replace the switch last year, but got stumped. The starter solenoid also failed at the same time which made my troubleshooting even more difficult. Anyway, I have everything figured out for the most part, except the kill circuit.
As I understand it, the kill circuit on these 2 strokes is a grounding system. It's an open circuit when in operation and closes to ground when the kill switch tether is pulled or the key is turned off to ground the coils. I have the kill switch tether working properly, but when I turn the key to the off position it doesn't kill the motor. There are two sets of wires I can't seem to trace to anywhere. One set of black wires (3 wires connecting to one terminal) and one set of purple wires also all connected to one terminal. The black ones trace to ground as one would expect, but the purple wires I can't find continuity with anything on the motor. I do notice that the alarm buzzer seems wired to the purple wires.
Can anyone help? I think I posted about this issue last year, and here I am again. Please help me from bringing this boat to my mechanic who is really good but about $150 an hour!
