A few Chatterbait variations this week.
Houston, TX & Crossville, TN
Using OnTheWater's Chatterbait primer
https://www.tinboats.net/forum/viewtopic.php?f=8&t=39633&p=402239&hilit=chatter#p402239
I bought some blades and have been messing around with a few rigs.
I modified the standard hook-side rig by using a Coastlock style clip on the end. That allows for changing the end hook/worm/jig etc. easily.
On one setup, I put a hook equipped with a screw-type Twist-lock on it. I added a simple split shot. The Split shot was squeezed onto the hook's shaft. It helps keep the worm and hook upright. Color was added by using a pipe-cleaner.
Just a fun few hours on a lazy day. FYI rich
    26.4 KB
    60.9 KB
    52.9 KB
    39.6 KB
    21.9 KB
Rich, If I were to put one of those small chatter blades a few inches in front of a hoochie or an in-line spinner (like a Mepps or wedding ring) would it give some wiggle action to the lures? I'm wondering if this might be another way to add some action while trolling without using a dodger. My slower trolling speed is in the 1.8 to 2 mph range. I'm thinking these would still have good action at that speed. The chatter blade might also be a nice small-scale attractor (trout like shiny things wiggling through the water - LOL).
richg99 said:
Yes, I think they add "wiggle" to anything they touch.
PM me your address and I'll snail-mail a couple of them to you.
rich
That is very generous. Who knows, this may revolutionize how we troll for trout. Haha
PM sent & Thanks!
A couple of blades to mess with are in the mail.
If I were to buy those blades again, I would buy the "bubbler" version. If you didn't want them to "bubble" you could just add a piece of tape over the holes.
Thank you Rich. I received them. I was going to head out tomorrow but it looks like it will be Friday instead. I'm looking forward to seeing how these do trolling.
I tried these out this past Friday. I used my buffing wheel & some rouge to get a decent shine on the blades. I put a chatter blade about 3” in front of a wedding ring. Holding it off the side of the boat, the action under water looks real good. However, even though I was using swivels, I had a pretty big problem with line twist. You know the kind so bad it wraps around your rod and you can't even reel it in. I was using about a 125’ setback and trolling at 2.6 to 3 mph. I need to do some more trial and error.
I think the blade needs to be right in front of the weight. 3" seems pretty far away. I would try using it with more weight or slow down the trolling speed. There's just not enough weight resistance to keep it from flipping over.
Thanks! I can do that pretty easily. A wedding ring weighs basically nothing. Maybe I'll add some weight and use a hoochie with two hooks. Next time out I'll give it a shot. I was hoping for next week, but doc appts and rain forecasts are getting in the way.
I had never heard of the Chatterbait before the last Bassmaster Magazine that contained a whole article on them. Tried them out this weekend on Tablerock Lake in Branson, MO with great success!
    79.8 KB
    68.7 KB
    76.1 KB
Jim, the only way I know to fix is copy them to a hosting site(IMGUR,ect.), edit to make them upright, then move to this site.
For example.
Whilst trolling, to prevent line twist when needed, I'll add a Luhr Jensen 'trolling rudder' a good 3' ahead of the lure. I'll also use good ball bearing swivels.
    5.1 KB
Thanks! I don't know why I didn't think of that. I have some of those somewhere. I agree with you on the ball bearing swivels. More expensive but worth it IMO. I had the chatter blade set up more like an attractor. Next time I'll set it up like a lure. That along with the rudder should work well. Hopefully I'll be back on the water in another month or so.
BTW, I seem to have avoided the sideways pic problem by making sure the images are well within the size parameters for the site before attaching them. I can't remember where I got the tip. Maybe it was someone here.
