Alumacraft transom question (2011 1542 model)
steelerfan88
Aside from the small piece of 1/2" plywood that is easily seen on the center of the transom covered in thin aluminum sheet, does anyone know if the larger portion of the transom has a wood core ? I can't see anything due to it being made/covered with aluminum. It almost feels/sounds like a hard foam core when I tap on it with the heel of my hand. Hey Bassboy.....I bet you can answer this for me quickly.
My boat was bought new last month and noticed the small piece of plywood on the transom's center covered in a thin aluminum skin has not been weatherproofed at the factory BUT I only have to drill out two rivets to remove it so I am going to go ahead and do that asap BEFORE any rot can start in the first place. I am going to use a piece of 1/2" marine ply sealed in epoxy resin then paint with enamel. This should last faaaaaaar longer than the unprotected wood the factory installed. I was kinda' dissapointed that such a big boat builder with a good reputation would install wood in the transom area and not even attempt to seal it against the elements. This will be a very easy replacement as the wood is not very big (4" x 16") and is easily accessable. I am just wondering if the large portion of the transom (that I can't inspect/see) has unprotected wood as well. That would NOT be such an easy replacement . I hope somebody knows the answer to this ......thanks in advance
Traditionally most boats have wood core transoms. The small piece on the outside you are referring too is is simply there so when you clamp an outboard motor it gives some tooth while protecting the back of the transom. It is made to be sacrificed and requires replacement every few years.
If the transom has a wood core, "it should unless Alumacraft has updated", since it's surrounded by metal it will be difficult and tedious to repair/replace. It's a job best suited to when you "have to."
Since that part is protected by metal and is above the waterline it should last for years. Make sure your boat is stored dry in the off season. I simply flip mine over. Even the outside piece should last for years.
You may could apply some varnish in the small piece if it bothers but honestly there's no need. It is as difficult to replace that "good wood" as rotten so I would use it as is and in ten years or so I would worry about it.
