ALUMACRAFT1448MV Elec. Reservoir Boat COMPLETE OVERHAUL!!!
<blockquote data-quote="lefty" data-source="post: 426581" data-attributes="member: 10142"><p>The ribs aren't attached to the boat but rather pressure forced against the bottom. The pictures before are from when I was mocking it up. </p><p></p><p></p><p>Today I began on removing the rear bench and more framing. I finished framing for the front deck installed the Ezy glide stick steer again and mounted the control box to the frame. </p><p>My previous build I had to route the cable in an odd way which put excessive tension on it making it a little hard to steer. </p><p>With gutting the decks I can now run it straight back and free up an additional 8-10" of cable. </p><p></p><p><img src="https://uploads.tapatalk-cdn.com/20170115/a1759cab823bc403289c402476b4b8cd.jpg" alt="" class="fr-fic fr-dii fr-draggable " style="" /></p><p></p><p></p><p>Sent from my iPhone using Tapatalk</p></blockquote><p></p>
[QUOTE="lefty, post: 426581, member: 10142"] The ribs aren't attached to the boat but rather pressure forced against the bottom. The pictures before are from when I was mocking it up. Today I began on removing the rear bench and more framing. I finished framing for the front deck installed the Ezy glide stick steer again and mounted the control box to the frame. My previous build I had to route the cable in an odd way which put excessive tension on it making it a little hard to steer. With gutting the decks I can now run it straight back and free up an additional 8-10" of cable. [img]https://uploads.tapatalk-cdn.com/20170115/a1759cab823bc403289c402476b4b8cd.jpg[/img] Sent from my iPhone using Tapatalk [/QUOTE]
