Another roughneck 1752 rebuild
<blockquote data-quote="JL8Jeff" data-source="post: 400029" data-attributes="member: 12995"><p>From what I have read, it sounds like the expanding foam has to be done in the proper conditions with the correct mixing to work and seal out water properly. It sounds like the foam blocks/sheets created in a controlled environment will work better and not soak up water over time. Seems to be lots of discussions/debates over what to use.</p><p></p><p>Here's a pretty good read.</p><p><a href="https://www.thehulltruth.com/boating-forum/316275-adding-foam-flotation-not.html" target="_blank">https://www.thehulltruth.com/boating-forum/316275-adding-foam-flotation-not.html</a></p></blockquote><p></p>
[QUOTE="JL8Jeff, post: 400029, member: 12995"] From what I have read, it sounds like the expanding foam has to be done in the proper conditions with the correct mixing to work and seal out water properly. It sounds like the foam blocks/sheets created in a controlled environment will work better and not soak up water over time. Seems to be lots of discussions/debates over what to use. Here's a pretty good read. [url]https://www.thehulltruth.com/boating-forum/316275-adding-foam-flotation-not.html[/url] [/QUOTE]
