Trailers
ATV Tires on Boat Trailer
<blockquote data-quote="rickybobbybend" data-source="post: 372747" data-attributes="member: 6145"><p>What earl said! </p><p>For most lighter tins, the max rated tire pressure is way too much even for asphalt, and dropping it even 10-15% really helps with the bounce. Off asphalt, dropping it more will make a noticeable improvement. If you are really off road, you still will be going real slow. Don't forget to air 'em back up</p></blockquote><p></p>
[QUOTE="rickybobbybend, post: 372747, member: 6145"] What earl said! For most lighter tins, the max rated tire pressure is way too much even for asphalt, and dropping it even 10-15% really helps with the bounce. Off asphalt, dropping it more will make a noticeable improvement. If you are really off road, you still will be going real slow. Don't forget to air 'em back up [/QUOTE]
Trailers
