Boat House
Battery Mounted under deck with OUT battery box
<blockquote data-quote="TMO8853" data-source="post: 467790" data-attributes="member: 23466"><p>I got it worked out so that the battery is sitting pretty much flat. I have some aluminum L channel that I will be using to make a tray for battery to sit in and hold it. Still not sure how I will strap it or protect it from water, but I’ll probably end using some rubber boots and engineer some sort of tie down if possible. </p><p></p><p>As far as venting goes, I do plan to close the front of the deck now that I’m adding hatch. I was hoping as long as I open hatch to charge it would be ok. </p><p></p><p>This 1436 is way to small... Already been looking at 1760’s and haven’t even got this one sorted out yet</p></blockquote><p></p>
[QUOTE="TMO8853, post: 467790, member: 23466"] I got it worked out so that the battery is sitting pretty much flat. I have some aluminum L channel that I will be using to make a tray for battery to sit in and hold it. Still not sure how I will strap it or protect it from water, but I’ll probably end using some rubber boots and engineer some sort of tie down if possible. As far as venting goes, I do plan to close the front of the deck now that I’m adding hatch. I was hoping as long as I open hatch to charge it would be ok. This 1436 is way to small... Already been looking at 1760’s and haven’t even got this one sorted out yet [/QUOTE]
Boat House
