Electrical
Battery Switch
<blockquote data-quote="zwseemm" data-source="post: 197932" data-attributes="member: 4707"><p>Anytime you connect 2 batteries together in parallel you risk shortening the battery life. If one is weaker the other will attemp to charge it. Charging them together or seperate wont change that. If you charge tem with 2 chargers you will have to disconnet the batteries from each other.</p></blockquote><p></p>
[QUOTE="zwseemm, post: 197932, member: 4707"] Anytime you connect 2 batteries together in parallel you risk shortening the battery life. If one is weaker the other will attemp to charge it. Charging them together or seperate wont change that. If you charge tem with 2 chargers you will have to disconnet the batteries from each other. [/QUOTE]
Electrical
Battery Switch
