wasilvers
If you are like me, you pull your batteries after every trip and charge them. I also unhook the batteries if I'm not useing the boat right away. The problem is, all the batteries I buy are not color coded but all my wiring is. The batteries just have a "+" or "-" in the black plastic, but if the light isn't shining right, it can be hard to see. This can be a problem when hooking up the wiring or charger! I used to take a sticker and put it next to the positive terminal so I could tell in the semidarkness what was what - of course that sticker didn't always stay on....
So last night I was painting some red on the boat and had an idea. I grabbed all my batteries and sprayed red paint near the "+" terminals - careful not to get it on the actual metal terminal. Now I can see clear across the garage which side is positve - it should be really easy to see which is which in the semi darkness before fishing
