Boat House
Benifits of Marine grad plywood
<blockquote data-quote="smoody" data-source="post: 96759" data-attributes="member: 804"><p>Marine grade ply is not "waterproof" and actually has NO water repelling characteristic. It is just simply more ply's with less void which in return gives you a stronger deck, when correctly waterproofed it will outlast all other in the marine environment. So if you plan to keep this boat the rest of your life, invest in the marine and epoxy it.</p><p></p><p>Good Luck</p></blockquote><p></p>
[QUOTE="smoody, post: 96759, member: 804"] Marine grade ply is not "waterproof" and actually has NO water repelling characteristic. It is just simply more ply's with less void which in return gives you a stronger deck, when correctly waterproofed it will outlast all other in the marine environment. So if you plan to keep this boat the rest of your life, invest in the marine and epoxy it. Good Luck [/QUOTE]
Boat House
