mossberg
- Joined
- Oct 18, 2023
- Messages
- 5
- Reaction score
- 1
- LOCATION
- Charlotte, NC
Hi everyone—
I'm redoing a late '80s Bass Tracker, stripping it down to the aluminum hull, adding cut-up closed foam sheets to floor/compartment walls, framing in some new hatches, replacing the transom, fixing leaks in hull, etc. I'd also like to re-add poured foam in places that make sense, but want to make sure the pour foam is isolated and not able to expand to fill in drainage channels. I pulled a lot of heavy, water-logged pour foam from the boat because most of the boat's drainage channels were completely blocked throughout the front and back of the boat by the pour foam and water had no place to go. I've fixed this.
I'd like to get your thoughts on my foam insulation plan.
Lastly, I've read concerns about sheet foam being used close to the transom and bilge, given that fuel that comes in contact with sheet foam will destroy it (I run a 60HP Johnson 2-stroke). So I was not going to install foam board in the last two ribs. I've also thought about taping the closed foam board closer to the back with aluminum HVAC tape as an additional layer of protection. Is that a bad idea?
Any thoughts, concerns or advice with the above plan? Thanks!
- Add measured, cut-up sheet foam (2" and 1" purple closed cell foam sheets from Home Depot) between boat ribs in floor (this keeps the drainage channels open)
- There is no drainage channel in the center of the boat (just two on the port and starboard sides). I'm planning to drill a 3/4 hole in the floor robs in the center of the boat to allow any trapped water to move.
- Put the aluminum subfloor (.060) and decking (.090) over the sheet foam between ribs.
- Fill in any gaps between compartment walls with sheet foam.
- After the boat is framed out and compartments created, and where it makes sense in the front and the back of the boat, add in pour foam, e.g., between PVC for rod locker, empty areas between side of hull, compartments, etc. This pour foam would be added to areas above the aluminum subfloor that are completely isolated in the front and back of the boat, adding back in places where it was previously.
- Just to state the obvious I will have added conduit and wired the boat before doing any pour foam anywhere.
