Boat modifications
<blockquote data-quote="CedarRiverScooter" data-source="post: 470177" data-attributes="member: 15465"><p>Nice boat! </p><p></p><p>To add floor you will have to make some supports that match the profile of the hull. I personally would just get some 1-1/2 foam board & cut the semi-circles from that. Sure it will absorb water over 10 years, but you could have the floor easily removable to access them.</p><p></p><p>If you remove center seat, you will lose some hull rigidity. That will take some engineering if you don't want to climb over struts or braces.</p></blockquote><p></p>
[QUOTE="CedarRiverScooter, post: 470177, member: 15465"] Nice boat! To add floor you will have to make some supports that match the profile of the hull. I personally would just get some 1-1/2 foam board & cut the semi-circles from that. Sure it will absorb water over 10 years, but you could have the floor easily removable to access them. If you remove center seat, you will lose some hull rigidity. That will take some engineering if you don't want to climb over struts or braces. [/QUOTE]
Boat modifications
